Following up on my earlier post about a rigid coil support (pasted below from a Google archive since the original post was deleted)…
I ended up using a 600 x 500 x 12 mm clear perspex sheet and had the supplier CNC two slots, 6 mm and 8 mm wide, and 6 mm deep, to house the coils. After some research, I found a much better epoxy than what was available at the local hardware store. This one is more fluid, wets well, and self-levels.
So far, I’ve added 10 turns of magnet wire in the transmit slot and poured enough epoxy to fill it to the top of the perspex (62 mL). However, I didn’t account for the wire volume, which led to a bit of an overflow. @Robert93820, you’re absolutely right about it being final!
For the receive slot, I lined it with copper conductive tape, which has adhesive on one side. It’s a bit fiddly, but the tape is fantastic. The adhesive is strong yet easy to reposition when needed, and the foil is durable—I only had a few small tears, and that was while trying to press it into a square-edged slot. The trick is to use plastic tools. Along the 1.7m lenfth my multimeter read 0 ohms - excellent.
The next step is to wind 50 turns of wire-wrap wire into the foil-lined channel, pour the epoxy, and complete the Faraday shield. My initial plan was to fold the tape over itself, but that probably won’t work due to the epoxy and tape width.
A simpler fix might be to lay another piece of foil, adhesive side down, against the foil lip. I tested the adhesive’s conductivity and found the resistance to be quite high until I applied a lot of pressure with the probes.
Before I proceed, I need to know:
If I press firmly while sticking it down, will it still create an effective Faraday shield?
Can anyone advise on this?
So far…
BTW, it’s still a pretty heavy unit, but I should be able to remove a significant amount of material without compromising the rigidity I need.
Roverling MkII and the Pulse Induction Metal Detector are almost ready to do some autonomous metal detecting. The trailer has been redesigned three times and a new desktop GUI provides so much more real time info at 20 samples per second over a LoRa link.
But I need some help. My previous coil housings were too flimsy and any bump, shake or flexing would result in a 20-100 mV change to my timed receive acquisitions, that are accurate to about 5nS. This is really bad when I need to detect down to 1mV changes. I’ve already managed to reduced electronic noise down to 100uV, so now it’s all physical.
In order to fix this problem, the coils you see here have been carefully epoxied (lots of) onto a 6.4 mm glass plate. The transmit coil is made of 10 turns of 24 AWG enameled magnet wire, whilst the receive coil is 50 turns of 30AWG Teflon insulated silver plated copper, AKA wire wrap wire. The receive coil has a Faraday shield made from conductive aluminium tape, but will be changed to copper in the next iteration. The trailer itself is made from PVC sheeting, and forms a bash plate that the glass sits on top of.
This system works really well now, with bumps and knocks no longer impacting the samples enough to cause a problem. However the new big problem is weight. The trailer is 6.8 kg without the battery, which has now been relocated to the front of Roverling for better weight distribution and to improve traction (front wheel drive).
But this setup is way too heavy. Roverling run time is reduced substantially and traction is a real problem, especially with the terrain around here. I know I could go back to the drawing board with Roverling, but I don’t want to go down that path.
What I really need is something that is very rigid, about 600x400mm, nonmetallic, light and not too costly, but I can’t think of anything suitable. I’ve been stumped for a while, so if anyone has got any ideas, I’d really like to know.
Thanks, Mark
PS. I’ll be offline until the New Year, so if you reply before then, I’m not ignoring you
PSS. Wishing everyone a great festive season![]()
Robert9382023 December 2024 06:3015
Hi Mark
The “very rigid” in that size is the hard part. You could think polycarbonate but by the time you met the “rigid” criteria it would probably be pretty heavy.
Unless you can get some thinner material and stiffen it up with some angle extrusions or box section material.
Cheers Bob2 Likes
Liam12034723 December 2024 10:2716
Hi Mark,
A cheap suggestion would be your geometries, if you add some spars along the top and bottom you could likely do away with the glass (it looks like this is the densest material).
If you can bind the two coils together and remove them from the glass, and replace that with some PC that will yield large weight savings.
(to put my thoughts into a photo, something like this : https://www.bunnings.com.au/all-set-100l-grey-and-green-heavy-duty-storage-container-with-flat-lid_p0406871)
MarkMakies30 December 2024 00:4417
Thanks for the suggestion @Liam120347. I have some of those at home, I get the idea, but these are very flexible.
MarkMakies30 December 2024 00:5218
Hey Bob,
I’ve taken a plunge, and for the first time collaborated with an AI system to come up with a suitable design, taking into account weight, rigidity, fabrication and cost. In my next iteration I will be trying 10mm perspex, with grooves routed on both sides to house the coils and material removed where it is not needed whilst maintaining rigidity. Grooves will then be filled with epoxy.
Robert9382030 December 2024 01:1419
Hi Mark
Sounds like a solution.You should make sure the whole thing works as expected before you go mad with any epoxy. That stuff can be pretty final.
Cheers Bob2 Likes
