This is a placeholder topic for “Rack Mount Enclosure for 5x Raspberry Pi (SSD)” comments.
Add more storage to your Pi with the rack mount case with optional SSD mounting
Read moreThis is a placeholder topic for “Rack Mount Enclosure for 5x Raspberry Pi (SSD)” comments.
Read moreAny idea if the rack mount here: Rack Mount Enclosure for 5x Raspberry Pi (SSD) | Buy in Australia | AC-U6264 | Core Electronics would fit the Pineboard HatDrive! PoE+ hat?
Hi Reece,
Looking at the HatDrive PoE+ HAT for Raspberry Pi 5 its difficult to tell whether or not the hat would fit in the enclosure, I would say there’s a pretty high chance that it would foul on just above the USB/Ethernet ports.
Hi, I have the AC-U6264 rackmount for up to 5 Raspberry Pi (SSD). If I wish to have a combination of model 4 and model 5 raspberry pi’s in this rackmount, is that possible? I understand that the model 4 and model 5 have switched the orientation of the LAN port, so I am hoping that I can buy a model 5 specific mount to install in the AC-U6264 frame for any model 5’s that I wish to install.
Kind Regards, Brad.
Hey there, @Brad266978 ,
You can definitely use a combination of Pi 4s and 5s with this rack unit.
The cut-out to access the peripheries is a solid rectangle that would be able to fit either the Pi 4 or the Pi 5, even with the flipped ports.
