Hi, I need to construct a pan tilt platform that will carry approximately 10kg of optical equipment.
All up moving weight may be about 15kg.
Constructing this system mechanically is not a problem, but items like shaft couplers and bearing blocks available with the chosen motors may make life easier.
A 360 degree pan turntable fitted with a fork mount tilt mechanism seems the best design option.
Pan tilt accuracy does not need to be to astronomical precision. +/- 1 degree is OK, ½ degree better but absolute pointing accuracy is not as important as the ability to move rapidly and settle on a new pan tilt pointing position. The platform must settle rapidly (0.5 sec) when it stops at a new pointing location.
The pan platform should be able to slew 180 degrees in 2 to 3 seconds meaning significantly powerful servos and drivers are needed. Duty cycle will be very low at this speed, < 1%, but the rapid pointing movement may well be at the motors thermal and electrical limits for a couple of seconds.
The tilt platform should be able to go from horizontal to 90 degrees (up) in the same time frame. Ideally, the tilt servo/motor will allow for 180 degrees of movement, ie horizon to horizon through the zenith but < 90 degree operation will be usual.
The Pan platform should be able to move through 360 degrees or almost 360 degrees, maybe limited only by the angular space occupied by safety limit switches if they end up occupying a small segment of the 360 degree pan arc.
I am looking at your 5303 geared DC motors with encoders and possibly the electronic driver RoboClaw 2 x 60 A.
Command and control will come from a laptop ideally via USB but other serial (RS232) or parallel connections could be designed in. RF connectivity is not preferred at this time.
Do you have any comments regarding product selection of 5303 geared DC motors with a RoboClaw 2 x 60 A controller or are there better options?
Can these motor/gear boxes be manually pushed if depowered or would I need clutches to detach them if the platform needs to be manually rotated? Ideally, I would like to depower the motors but leave the shaft encoders on line so pan/tilt tracking calibration is retained.
I am assuming that a stepper motor through a torque multiplying gearbox will be too slow. Is this assumption correct?
Thanks for your help.
Mike
