Hi looking to up date from a PI W Zero. Using a Hdmi screen with power from the W Zero via a mini connector. Is there one on the PI 3 Model A+ can only see a power input and a HDMI output tks
I will be using it for a Tilt Pi and this is the file I need to put in the config text for the HDMI monitor
Will this work tks
max_usb_current=1
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
Hi John,
I know we discussed this, but posting here for others’ reference:
Yes, there is a USB A Female port on the Pi 3A+ which can be used for 5V USB power output, the same as the Micro USB port on the Pi Zero boards. The Pi 3A+ also has a full-size HDMI connector.
I’m not sure of the details of your screen, so you will have to check those but on face value, it should work.
Regards,
Oliver
Core Electronics | Support
