Yes, but the whole thing was made … worse? By RasPi not being compliant with industry standards of python.
All other systems use pip to install the latest version of python. Be it 2, 3, 4, 5… what ever.
The Pi needs to me to use pip3 to install python3 files.
Then, when I install the python2 stuff and am then told the problem is because I haven’t installed the latest version - for python3.
Yet, when I install that, the problem remains.
Then the commands that can be sent to the display not being documented in the python3 stuff. Yet they were a lot of good example files with the python2 stuff.
Don’t worry about it. I’ll get it worked out eventually.
Though as I did say it would be nicer is Sparkfun put a bit more effort in what is supplied.
Even a basic piece of paper with the links to software which is needed to talk to the device.
I’ve now been there and done that and I now have the python3 software.
But still there is a chronic lack of documentation of what commands are; their syntax and what they do.
If you want full instructions buy products that give full instructions. In most cases you will not get this because it is all available online via a simple search. You learn by working it out not by being given everything.
Raspberry Pi OS is a linux dist like any other and is fully compliant.
There is Python 2 and Python 3, I believe both are installed. Pip is used to install modules and not install Python.
Both Python 2 and 3 (2 is being phased out now) have pip and pip(2 or 3) executables, if you call pip you get the first one found on the path statement. if you uninstall python 2 you will only get pip from python 3, if you change the path or links you can control it.
So if you want to install a module into python 2 type pip2 if you want to install in python 3 use pip3.
You need to work out which version of python you are using.
python --version will tell you which is the DEFAULT version of python.
It sounds like you are installing modules into Python 2 but running a Python 3 script (focus on 3 as 2 is going away soon)
So run pip commands as pip3 install module and run your script using python3 scriptname.py
There is so much documentation online about all of it that it is insane. Remember you learn more by working it out yourself.
BTW Python 3 isn’t that much different to 2, there are changes but that is things like the print statement, 2 supports print “some text” but 3 supports print(“some text”) plus heaps of new features.
You need a better understanding of Linux I suspect, that will help you understand what is going on. This is what the Raspberry Pi is so good at, giving you a system you can play with and learn, if you screw up who cares, as long as you backup the work you have done you can re-install the OS in a short time and be back at it.
I suggest if you have a pc or other get Bitvise SSH client. It will log you into your Pi, supply a terminal window and ftp file access so you can copy scripts etc you write from the pi to another location, easy backups.
Also lookup Headless setup, this will show you how to enable SSH and wifi before you boot the first time so the pi is online as soon as it starts and you can remote in.
Excellent idea, glad to hear you’ve fixed it up. Feel free to use this resource any time with your questions regarding your code and projects. If you’re looking for pure code debugging I’d suggest using Stack Overflow too, most devs on there should be able to assist with your code directly as well as this forum. Have a great day!
I haven’t checked, but this may be very simple. If the different version of python are set up using the Debian Alternatives system, a simple call to updatealternatives will change everything. If the slaves like pip are configured properly, they will be handled as well.
