I’ve followed your guide on your site for stress testing the raspberry pi.
I still cant generate a graph from your stress test results the error I get is this
I read the comments where a guy said he also got the same error and he fixed it but removing the last bits of code but that also didn’t fix the issue for me.
…if it still fails remove the program and reboot the rpi and start the install again…
reboot
can you pls post the exact code you used with stressberry program
check the gpio pins see if you have 3.3 and 5 volts…
can you pls take a snapshot of your exact error…so the guys can see your errors
have you defined values in “config.txt”
and if so what are they …??
#: did you create the directory structure correctly
1:search drive for the file…or sd-card try find it…
2: did it create the file
3: if so where did it put the file …the pointers or paths are not matching up for some reason…
Yes, the issue is with the arguments that are being used in this case, we’re going to be updating the tutorial we’ve got online soon once we’re certain that the new version is running correctly and whether any other changes need to be made to it. For now, you should be able to remove the arguments (or just run these) and you shouldn’t be getting any error messages (make sure to send us another screenshot if you do)
/home/pi/.local/bin/stressberry-run -n "My Test" -d 1800 -i 300 -c 4 mytest.out - This should run without an issue
MPLBACKEND=Agg /home/pi/.local/bin/stressberry-plot mytest.out -f -d 300 -f -l 400 1600 -t 30 90 -o mytest.png --not-transparent - The hide legend and line width arguments have now been removed as seen in lines 78-136 in the file I’ve attached below
Also, try running this first if you get the same ‘file does not exist’ error message: touch /home/pi/.local/bin/stressberry-run mytest.out
Please let us know if you have any other issues with it. All the best with your Pi!
it was the code i used when i was doing the stressing with the over clocking ,but i modded it slightly to give 64 threads an or how ever many i ran at the time…and less wait times
…who knows what it could do if i had my hands on some liquid nitrogen…i would have submersed the whole board in it just with a single blue heat sink…!!
/root/pi/.local/bin/stressberry-run -n "My Test" -d 1800 -i 300 -c 4 mytest.out /root/.local/bin/stressberry-run -n "My Test" -d 1800 -i 300 -c 4 mytest.out /root/home/pi/.local/bin/stressberry-run -n "My Test" -d 1800 -i 300 -c 4 mytest.out
one of these should work in a terminal…
picking up my pi today i hope my old one blew up…so i should be bak in the game this arvo…
normally i would sole easier…if still no avail after this code …
sudo purge stress
reboot
reopen terminal as root user and open it full screen expand it ..
cd /
apt install stress
pip3 install --stressberry -user
check with the stress berry tutorial…for the reinstall…??
as the code runs down the screen watch closely as to what directory the installer placed the files there will be a few
now find the one that starts with “/root/XX/XX/” /stressberry…etc…etc…
you will want to change into the root of the dir where it installed it …
next try the codes to start the programs as per earlier…or just reinstalling it could fix it…!!
p.ss the pip 3 line may be incorrect check stress-berry install guide for installation…
there has been problems with the program lately somebody modded the workings of it and the guys are working on it ...last time i used it it was ok 1 month ago approx.. so im not shure…atm,
just got my new rpi 2 nite so i`ll take a look at it my self…this week…try this line…below…
Hi Brian so I figured out why its failing on this guide I followed this link
so I had previous done these commands.
sudo apt update
sudo apt full-upgrade
Now to install Stressberry:
sudo apt install stress
however the last command I thought I would see if it was failing because I didnt do this command. I only did this command without the user at the end, as soon as I ran this full command, it started stress testing im now just waiting on my results. I hope that once the test is done I can graph my results without any issues.
Sorry that I haven’t gotten back to you for a few days, I haven’t been here in the office too much recently. Glad to see that the fix on the script parameters has worked successfully! It looks like that Pi has also done very well on the test, must have some nice cool space around it to radiate into. If there’s anything else that we can do for you please let us know.
Dont be silly we all have our own lives to live and enjoy so no harm done mate
I actually am very pleased with the case thats not overclocked so I might be game enough to test out and OC but atm I am still trying to fix a video issue I’m having its really strange.
So if I shutdown the Pi leave it off for two hours turn it back on no issue with display.
If i reboot the Pi for what ever reason I dont get a video display until I unplug and replug the HDMI cable super weird… not sure whats going on tested on multiple monitors same issue.
I think I might have a solution! I put this tutorial up this time last year that solves most issues that users might have with the video display on the Pi 4.
