I am loking to remote control my two bldc motor. The setup has each motor attached to a motor controller that are both connected by an Arduino Due. I need the remote control to simple control the pwm signal inputted. It just needs to go from 0 - 100% speed. Any suggestions are appreciated.
We’ll need more info on your motors to make a good recommendation, as they vary a bit in their wiring and capabilities.
The first thing that comes to mind is SparkFun’s board based on a TMC brushless control IC, I’d have a read through the description, especially the caveats about required PWM capabilities (this may mean your Due isn’t suitable, but I’m not sure at a glance)
At first glance, I was thinking an RC servo control system would be appropriate, but that only has a small variance in duty cycle as that’s what servos expect:
Perhaps a serial radio would be a good idea? That way you can have a microcontroller on the remote side reading a pot, and your Due taking in serial data and outputting PWM.
What sort of range do you need? That decides what sort of radio I should suggest.
