What I need it to reprogram it to 915B ( 915-228 MHz, with frequency hopping from 902 to 915 disabled ) for Australian use, but can’t get the software working.
Does anyone know of an updated programmed that works with Windows 10, or have a copy of the configuration strings to program it up for AU use?
Hi David
According to the Data sheet linked on Core website for this unit it is 418 - 455MHz with a default of 434MHz so good luck with 915MHz.
I just looked and the user guide has slightly different numbers but it is all there.
Hi Liam
You have a shield alongside your name so I am assuming you are a Core employee. Right???
I don’t believe I am reading this. Your (Core) page for this product (link above) has a user guide, Data sheet and product Wiki and at first glance ( which is what I just did) between all of this I think pretty much everything is covered.
I think Liam meant more about how the connection is created - typically wireless modules like these provide documentation for setting them up through registers or AT-commands. At a glance I couldn’t find these either.
Hi Liam
It would seem there is a software package to download to set up the modules if the default won’t do for whatever reason. I clicked the button accidentally and it downloaded to my mac which would be a bit useless I think (Windows software). It is called rfmagic. I think there is some convoluted method to do it on line too. I did not go into detail as at the moment I have little interest.
David is talking about 915MHz anyway. Don’t think this device will do that. Could be wrong though, has happened before.
The datasheet shows how to set it up using a UART connection and some commands.
“For example , one APC220-43 is set to 434MHZ; rf data rate is 9600bps; Output
power is 20mW; UART data rate is 1200bps; No checkout.
WR_434000_3_9_0_0↙
(HEX code: 0x57,0x52,0x20,0x34,0x33,0x34,0x30,0x30,0x30,0x20,0x33,0x20,0x39,
0x20,0x30,0x20,0x30,0x0D,0x0A)
ANSWER: PARA_434000_3_9_0_0↙
(HEX code:0x50,0x41,0x52,0x410x20,0x34,0x33,0x34,0x30,0x30,0x30,0x20,0x33,
0x20,0x39,0x20,0x30,0x20,0x30,0x0D,0x0A)”
Everything after the frequency is a code number from some tables that are also listed.
But the point is moot if OP can’t establish the UART connection.
It does appear Bob is correct - I’m not sure on reviewing why I thought they did 915MHz. I think it’s the way that Core write their website, but it’s clear on review that these modules don’t support it. I missed that the data string needed is in the app note - seems what is needed is to manually connect the missing pin for programming mode and see if it responds.
I managed to find some good long-range 915MHz AU compliant radios elsewhere, so have a long term solution, but I’ll see if I can get into the programming mode without the software and how that goes.
