Hey gang,
So I have my rpi4 running batocera with minimal issue; however I’m trying like mad to map a usb n64 controller to better play those console titles.
I finally found a walkthrough I could follow, however I cannot access the file menu!
I’ve the rpi4 keyboard model.
The walkthrough shows the access via F1 button on the bottom of his screen Link to YouTube walkthrough,
though my Home Screen does not show it?
Thanks in advance for any help.
James.
Hi James,
Welcome to the forum
Do you mean you are using a Raspberry Pi400? The F1 key is a little strange on the Pi400 because it is shared with F11. So if you just hit the key on its own it should register as F1, but if you hold down function + F1 you’ll get F11.
I hope this doesn’t sound patronizing, but I’ve just spent several days chasing down an equally minor mixup in my own unrelated project so it’s always worth ruling out the obvious stuff first.
Alternatively, if you use a different keyboard do you get the same result?
