Hi, I am currently working on a new project for an upcoming art exhibition. This sound equipment is very new to me so I am apologising for my lack of knowledge right now. I am hoping to record sounds from the environment and have them vibrate through a sheet of glass (around the size of a kitchen table). I mostly interested in the vibration effect through the glass but would also like an option to listen to the sound through a set of headphones. I am looking at using a surface transducer and amplifier to achieve the vibration effect. Is it actually possible to isolate off the sound through a set of headphones so that the work is focused on vibration from the sound recording???
If I am to purchase a Large Surface Transducer with Wires - 4 Ohm 5 Watt or Medium Surface Transducer with Wires - 4 Ohm 3 Watt with a Stereo 2.1W Class D Audio Amplifier - TPA2012 what other equipment will I need to set it up? I have watched a few tutorials so far but I cant find one which shows how to actually connect the parts. Also how do you input the the power and sound source?? What do you need here. Any assistance would be greatly appreciated.
Joe (amateur and beginner)
