We will be making arduino based pinball machines with 110 year 7 students in 2019. Can anyone suggest the best sensor to use / way of detecting a collision?
Ta
Mark
Ta
Mark
Hi Mark,
I think that a good sensor might be a force sensor like this one:
This would change resistance when pressed or touched.
Another option might be a well positioned microswitch such as this:
This would be a bit easier to work with!
Let me know what you think!
Hi Stephen,
Thanks for your reply. The switch is likely to work the best out of those two. We will see if we can design a simple way of incorporating it.
I was wondering if I could wrap a bumper in conductive thread and use an analog input to trigger lights when the resistance and hence the voltage at the pin dropped?
Ta
Mark
Hi Mark,
That’s an interesting idea! You could probably incorporate capacitive touch in some way:
Hi Stephen,
I was at a course yesterday with an expert in all things Arduino and robotics and he suggested using an accelerometer to detect movement / vibration. Do you think that would work? I was thinking that may be a problem if the player moves the pinball machine itself rather than the ball actually hitting the sensor?
Ta
Mark
You might want to look through the videos Ben Heck and his team made, where they designed a tiny pinball machine. There may be some useful information and tips you can glean from their build. https://www.youtube.com/watch?v=CD_DIaPgkDQ&list=PLwO8CTSLTkihDZlIL4i5JH_eaDMpXtiKT
Mark,
If you use an accelerometer it would not be able to tell the difference between a ball striking the sensor and a hand striking the machine, as both would induce acceleration on the sensor in basically the same way. I also think that is a pretty complex solution to a rather simple problem. While a pinball machine can be made with digital components such as that, you can very likely find a way to build one using only analog components just like they used to be made.
Thanks guys. That Ben Heck video was pretty awesome! I spoke with Graham today and he convinced me that the micro switch is the way to go. We will just design something to prevent it being damaged
Ta
Mark
