This is a placeholder topic for “Servo extension cable 300mm” comments.
This is a 300mm servo extension cable. This comes in very handy when your servo is further away from the controller than the wire on the servo allows.
Read moreThis is a placeholder topic for “Servo extension cable 300mm” comments.
Read moreRe: Servo extension cables. Are these copper and if so, what size is the wire?
Hi David,
We don’t have any info of the composition from our supplier, but I assume you’re wondering about the current capability.
I ran a test with one of these and a benchtop power supply, and was able to push through 3A continuously before the jumper wires I was using to hook into this lead got hot and flexible enough that I backed off.
Seems it is a reasonably thick gauge, and the insulation felt flexible, so it may be of a nicer grade than just the standard PVC you see on cheap jumper leads.
