USB Type C Extension Cable - 2 meters long (ADA5216)
This is a placeholder topic for “USB Type C Extension Cable - 2 meters long” comments.
If you have a USB Type C port on your computer over here and you want to connect something over there then this extension cable will do the job right…
What is the wattage rating of this cable?
Cables aren’t rated for wattage, they are rated for current. USB-C is rated for 3A (unless electronically marked as 5A capable), so these cables will be capable of 3A.
With USB-PD (Power Delivery), a standard power range cable can deliver up to 60W (3A@20V), though at the normal 5V, this same cable can deliver up to 15W (5V @ 3A).
You can get special extended power range cables that are capable of up to 5A at up to 48V (240W).
