This is a placeholder topic for “Slim Case for Raspberry Pi Zero” comments.
A well protected Pi is a happy Pi! The Slim Case for the Pi Zero is perfect for keeping your Pi Zero protected from damage, without adding unnecessary bulk
Read moreThis is a placeholder topic for “Slim Case for Raspberry Pi Zero” comments.
Read moreOk, well I have this case and it’s really good, but for some reason I’m not allowed a review. I put a Zero 2 in it, before seeing it "isn’t"compatible, and it works fine. One thing I’d love is if the case had an add-on to suit the Zero4U hub! The case also is a good fit to protect a Pi attached to a hyperpixel display.
Hi David,
Odd! Perhaps you weren’t logged in at the time, or you have multiple email addresses and multiple accounts?
Nonetheless, thanks for the great feedback
The reason it’s not compatible is that we had to make some cutouts in the acrylic for some of the SMT components, which of course are different between the original and the Zero 2, so they may be getting a bit squished! But if it works and you’re happy, so am I!
Hi support, can you please advise if: SKU: CE06235 is a compatible case for the PiZero W ?
Hey @Taras205611, welcome to the forums!
I can confirm that this case will fit the Raspberry Pi Zero W (Wireless). I have one sitting in this case on my desk right now!
The form factor differences between the Pi Zero and the Pi Zero W are not significant enough to effect what cases they are compatible with. ![]()
Hi, checking for the Zero 2 W as well - will this case fit?
Hey @William208186 ,
Unfortunately, this one won’t fit the Pi Zero 2W as the slight differences between the boards cause some compatibility problems.
The closest alternative to fit a Zero 2W would be this Pibow Case:
Hope this helps!
