This is a placeholder topic for “The Pi Hut Pi Zero Camera Case” comments.
This case is perfect for combining your love for Raspberry Pi and Cameras!
Read moreThis is a placeholder topic for “The Pi Hut Pi Zero Camera Case” comments.
Read morewould this product:
find inside this:
Hi Anderson,
I’ve test-fit one of these on the bench, and found that the mounting holes are quite a bit different between the case and the camera. The camera lens does just fit in through the hole in the case, but will not “seat” fully, so it wouldn’t be a good fit (and the IR LEDs complicate things further). I’d recommend going with a standard NoIR camera, or a 3d-printed case.
Dear Core Electronics,
Is this case compatible with Pi Zero 2W (with the Camera Module 3 which I understand is supported)?
Thanks in advance,
John
Hey John,
Yes, the mounting points and required dimensions are the same, I put one together here for you to double check and you should have plenty of clearance. Although note that the if you have a long ribbon cable adapter to your camera you’ll need to gently fold it a little to fit inside the case.
what ribbon cable do you recommend? I tried to fit my zero 2w into the official case with a cam 3, but the cam 3 profil was too thick, so I got this case instead but the cable that came with the official case is too short.
