These are like the fancy electronics equivalent of the wire nuts electricians use to bind wires together. They are a lot easier to use as well! Each block connector…
I just need to know that I understand how these work.
If I put a positive(powered) wire in one slot the other slots will all carry the power to where I need it.
Hi Adam
Yes the description is a bit hazy isn’t it. I think all the connection points ARE joined together. There does not seem to be an “IN” and “OUT” as in a “normal” terminal block. Also the entry in the data list says
" * No. of connection Points - 5
No. of potentials - 1"
Which would support that idea.
Core might clarify this. Although you might have to wait for stock to arrive for that to happen.
Can confirm that Rob is correct, all 5 terminals are connected together electrically. Connecting a wire to one terminal will connect them to all the others. Been using these for a while and they are super handy for projects before they get made on protoboard.
