The SparkFun NEO-M9N GPS Breakout is a high quality GPS board with equally impressive configuration options including SMA. The NEO-M9N module is a 92-channel u-blox…
Hi I am after a through bolt low profile mushroom bulkhead antenna for this GPS.
Could you help me with what specifications I need for an antenna?
SparkFun GPS Breakout - NEO-M9N, SMA (Qwiic
Hi there, @rusell51010, and welcome to the forum, glad to have you here.
Off the top of my head I can immediately tell you that you need a male SMA antenna, but that is about all I can tell you without knowing what your use case would be.
