I need to replace a speaker in my car’s instrument cluster. Apparently the original is 2w @ 60 Ohms but someone suggested 100ohms works.
I found this
Which is apparently retired product but the page links to a replacement product, which I bought.
I didn’t realize the replacement product is 0.1w @ 8 ohms.
Will this still work? Am I going to fry anything? Or will it be too quiet or loud?
Or can I modify it to work somehow?
Hi Sa
Welcome
100 Ohm would work but 8 Ohm would probably be too much of a load for the driver. The 0.1W is the power handling capability of the speaker and is no necessarily the power being applied. You probably would not live with 2W inside a car.
The short answer is probably. And frying a part of the car electronics could be expensive. Personally I would not even think about it.
PS: that is not exactly a replacement product is it. The physical size might be the same or similar but that is about where it ends. Hard to get people these days who look at everything. Especially important things like speaker impedance.
Sorry that replacement lead you astray. I’ve made a note to try and get that link removed.
FWIW, perhaps a small class D amp could address the impedance disparity? I had a look and while the chips we break out don’t quote an input impedance it’s usually quite high, perhaps you could also incorporate a part in the chain that does? (op-amp)? Of course if you can find a closer match for the speaker elsewhere, that would be a much easier option.
