Dear all
First post and first try with Steppers
Have a Tic T825 driver board and a Linux Mint system
Cant get past first base - computer will not recognize the board via USB
On the board Red fault LED is on continuously
Green flashing about 0.5 sec on/off
Orange same but at different time (indicates no motor power supply) - this should not matter
Have loaded the permissions file to /etc/udev/rules.d/99-polulu.rules
I note there is no device ID and no group in the file
Anyone had a similar problem and/or solution?
Does anyone know the device ID?
Are you sure? The DRV8825 chip that this module uses gets its logic power from the motor supply. Without a motor supply the logic won’t be running, and presumably it wouldn’t respond to the USB interface.
Thanks Jeff
I just wanted to see the USB
The ticgui program seems to work without a motor supply
I think the motor supply drives the (presumably) H bridge which drives the motor coils directly
but not much else
Anyway working now
R
