This is the configuration on my Raspberry pi 4 model B+
My target.config
# That file will be included in the Makefiles to configure where to install files on the target
# The IP address of the gateway host on which the files need to be installed
TARGET_IP=192.168.118.44
# The directory on the gateway file system to which the files need to be installed
TARGET_DIR=/home/smartnest/Desktop/TTN/sx1302_hal/bin
# The user to be used by ssh/scp to copy the files on the gateway host
TARGET_USR=smartnest
My global_conf.json.sx1250.AU915
"SX130x_conf": {
"com_type": "SPI",
"com_path": "/dev/spidev0.0",
"lorawan_public": true,
"clksrc": 0,
"antenna_gain": 0, /* antenna gain, in dBi */
"full_duplex": false,
"fine_timestamp": {
"enable": false,
"mode": "all_sf" /* high_capacity or all_sf */
"sx1261_conf": {
"spi_path": "/dev/spidev0.1",
"rssi_offset": 0, /* dB */
"spectral_scan": {
"enable": false,
"freq_start": 867100000,
"nb_chan": 8,
"nb_scan": 2000,
"pace_s": 10
"lbt": {
"enable": false,
"rssi_target": -70, /* dBm */
"channels":[ /* 16 channels maximum */
{ "freq_hz": 867100000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 867300000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 867500000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 867700000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 867900000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 868100000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 868300000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 868500000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 869525000, "bandwidth": 125000, "scan_time_us": 5000 "transmit_time_ms": 4000 },
{ "freq_hz": 868300000, "bandwidth": 250000, "scan_time_us": 128, "transmit_time_ms": 400 }
"radio_0": {
"enable": true,
"type": "SX1250",
"freq": 917200000,
"rssi_offset": -166,
"rssi_tcomp": {"coeff_a": 0, "coeff_b": 0, "coeff_c": 20.41, "coeff_d":
2162.56, "coeff_e": 0},
"tx_enable": true,
"tx_freq_min": 915000000,
"tx_freq_max": 928000000,
"tx_gain_lut":[
{"rf_power": -6, "pa_gain": 0, "pwr_idx": 15},
{"rf_power": -3, "pa_gain": 0, "pwr_idx": 16},
{"rf_power": 0, "pa_gain": 0, "pwr_idx": 17},
{"rf_power": 3, "pa_gain": 1, "pwr_idx": 19},
{"rf_power": 6, "pa_gain": 1, "pwr_idx": 20},
{"rf_power": 10, "pa_gain": 1, "pwr_idx": 22},
{"rf_power": 11, "pa_gain": 1, "pwr_idx": 1},
{"rf_power": 12, "pa_gain": 2, "pwr_idx": 2},
{"rf_power": 13, "pa_gain": 1, "pwr_idx": 3},
{"rf_power": 14, "pa_gain": 2, "pwr_idx": 4},
{"rf_power": 16, "pa_gain": 2, "pwr_idx": 5},
{"rf_power": 20, "pa_gain": 3, "pwr_idx": 6},
{"rf_power": 23, "pa_gain": 3, "pwr_idx": 7},
{"rf_power": 25, "pa_gain": 3, "pwr_idx": 9},
{"rf_power": 26, "pa_gain": 3, "pwr_idx": 11},
{"rf_power": 27, "pa_gain": 1, "pwr_idx": 14}
"radio_1": {
"enable": true,
"type": "SX1250",
"freq": 917900000,
"tx_enable": false
"chan_multiSF_All": {"spreading_factor_enable": [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
"chan_multiSF_0": {"enable": true, "radio": 0, "if": -400000},
"chan_multiSF_1": {"enable": true, "radio": 0, "if": -200000},
"chan_multiSF_2": {"enable": true, "radio": 0, "if": 0},
"chan_multiSF_3": {"enable": true, "radio": 0, "if": 200000},
"chan_multiSF_4": {"enable": true, "radio": 1, "if": -300000},
"chan_multiSF_5": {"enable": true, "radio": 1, "if": -100000},
"chan_multiSF_6": {"enable": true, "radio": 1, "if": 100000},
"chan_multiSF_7": {"enable": true, "radio": 1, "if": 300000},
"chan_Lora_std": {"enable": true, "radio": 0, "if": 300000, "bandwidth":
500000, "spread_factor": 8},
"chan_FSK": {"enable": false}
"gateway_conf": {
"gateway_ID": "0016c001f15d6662",
/* change with default server address/ports */
"server_address": "au1.cloud.thethings.network",
"serv_port_up": 1700,
"serv_port_down": 1700,
/* adjust the following parameters for your network */
"keepalive_interval": 10,
"stat_interval": 60,
"push_timeout_ms": 100,
/* forward only valid packets */
"forward_crc_valid": true,
"forward_crc_error": false,
"forward_crc_disabled": false,
/* GPS configuration */
"gps_tty_path": "/dev/ttyS0",
/* GPS reference coordinates */
"ref_latitude": 0.0,
"ref_longitude": 0.0,
"ref_altitude": 0,
"servers": [
"serv_enabled": true
"debug_conf": {
"ref_payload":[
{"id": "0xCAFE1234"},
{"id": "0xCAFE2345"}
"log_file": "loragw_hal.log"
This is the result I am getting when I ran ./lora_pkt_fwd -c global_conf.json.sx1250.AU915
*** Packet Forwarder ***
Version: 2.1.0
*** SX1302 HAL library version info ***
Version: 2.1.0;
INFO: Little endian host
INFO: found configuration file global_conf.json.sx1250.AU915, parsing it
INFO: global_conf.json.sx1250.AU915 does contain a JSON object named SX130x_conf, parsing SX1302 parameters
INFO: com_type SPI, com_path /dev/spidev0.0, lorawan_public 1, clksrc 0, full_duplex 0
INFO: antenna_gain 0 dBi
INFO: Configuring legacy timestamp
INFO: Configuring Tx Gain LUT for rf_chain 0 with 16 indexes for sx1250
INFO: radio 0 enabled (type SX1250), center frequency 917200000, RSSI offset -166.000000, tx enabled 1, single input mode 0
INFO: radio 1 enabled (type SX1250), center frequency 917900000, RSSI offset -166.000000, tx enabled 0, single input mode 0
INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8, Explicit header
INFO: FSK channel 8 disabled
INFO: global_conf.json.sx1250.AU915 does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to 0016C001F15D6662
INFO: server hostname or IP address is configured to "au1.cloud.thethings.network"
INFO: upstream port is configured to "1700"
INFO: downstream port is configured to "1700"
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 60 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with no CRC will NOT be forwarded
INFO: GPS serial port path is configured to "/dev/ttyS0"
INFO: Reference latitude is configured to 0.000000 deg
INFO: Reference longitude is configured to 0.000000 deg
INFO: Reference altitude is configured to 0 meters
INFO: global_conf.json.sx1250.AU915 does contain a JSON object named debug_conf, parsing debug parameters
INFO: got 2 debug reference payload
INFO: reference payload ID 0 is 0xCAFE1234
INFO: reference payload ID 1 is 0xCAFE2345
INFO: setting debug log file name to loragw_hal.log
WARNING: [main] impossible to open /dev/ttyS0 for GPS sync (check permissions)
CoreCell power enable on through GPIO18...
CoreCell reset through GPIO23...
SX1261 reset through GPIO22...
CoreCell ADC reset through GPIO13...
Opening SPI communication interface
Note: chip version is 0x12 (v1.2)
INFO: using legacy timestamp
INFO: LoRa Service modem: configuring preamble size to 8 symbols
ARB: dual demodulation disabled for all SF
INFO: found temperature sensor on port 0x39
INFO: [main] concentrator started, packet can now be received
INFO: concentrator EUI: 0x0016c001f15d6662
INFO: [down] PULL_ACK received in 94 ms
INFO: [down] PULL_ACK received in 48 ms
INFO: [down] PULL_ACK received in 57 ms
INFO: [down] PULL_ACK received in 81 ms
INFO: [down] PULL_ACK received in 118 ms
INFO: [down] PULL_ACK received in 50 ms
##### 2024-09-26 12:04:14 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 0
# CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# RF packets forwarded: 0 (0 bytes)
# PUSH_DATA datagrams sent: 0 (0 bytes)
# PUSH_DATA acknowledged: 0.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 6 (100.00% acknowledged)
# PULL_RESP(onse) datagrams received: 0 (0 bytes)
# RF packets sent to concentrator: 0 (0 bytes)
# TX errors: 0
### SX1302 Status ###
# SX1302 counter (INST): 60904350
# SX1302 counter (PPS): 60086332
# BEACON queued: 0
# BEACON sent so far: 0
# BEACON rejected: 0
### [JIT] ###
src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
### [GPS] ###
# GPS sync is disabled
### Concentrator temperature: 33 C ###
##### END #####
And I am not able to connect to TTN. I have my gateway as “DISCONNECTED”
LORAWAN MODULE PINOUT
