Hey, thanks again!
Here are the changes I’ve made:
- Disabled Bluetooth in
/boot/config.txt.
- Moved the GPS from
/dev/ttyS0 to /dev/ttyAMA0.
This is the output when I run cat /dev/ttyAMA0:
Does this look better?
By the way, this is the content of my global_conf.json.sx1250.AU915 file:
"SX130x_conf": {
"com_type": "SPI",
"com_path": "/dev/spidev0.0",
"lorawan_public": true,
"clksrc": 1,
"antenna_gain": 5, /* antenna gain, in dBi */
"full_duplex": false,
"fine_timestamp": {
"enable": false,
"mode": "all_sf" /* high_capacity or all_sf */
"sx1261_conf": {
"spi_path": "/dev/spidev0.1",
"rssi_offset": 0, /* dB */
"spectral_scan": {
"enable": false,
"freq_start": 867100000,
"nb_chan": 8,
"nb_scan": 2000,
"pace_s": 10
"lbt": {
"enable": false,
"rssi_target": -70, /* dBm */
"channels":[ /* 16 channels maximum */
{ "freq_hz": 867100000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 867300000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 867500000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 867700000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 867900000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 868100000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 868300000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 868500000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400 },
{ "freq_hz": 869525000, "bandwidth": 125000, "scan_time_us": 5000, "transmit_time_ms": 4000 },
{ "freq_hz": 868300000, "bandwidth": 250000, "scan_time_us": 128, "transmit_time_ms": 400 }
"radio_0": {
"enable": true,
"type": "SX1250",
"freq": 917200000,
"rssi_offset": -166,
"rssi_tcomp": {"coeff_a": 0, "coeff_b": 0, "coeff_c": 20.41, "coeff_d": 2162.56, "coeff_e": 0},
"tx_enable": true,
"tx_freq_min": 915000000,
"tx_freq_max": 928000000,
"tx_gain_lut":[
{"rf_power": -6, "pa_gain": 0, "pwr_idx": 15},
{"rf_power": -3, "pa_gain": 0, "pwr_idx": 16},
{"rf_power": 0, "pa_gain": 0, "pwr_idx": 17},
{"rf_power": 3, "pa_gain": 1, "pwr_idx": 19},
{"rf_power": 6, "pa_gain": 1, "pwr_idx": 20},
{"rf_power": 10, "pa_gain": 1, "pwr_idx": 22},
{"rf_power": 11, "pa_gain": 1, "pwr_idx": 1},
{"rf_power": 12, "pa_gain": 2, "pwr_idx": 2},
{"rf_power": 13, "pa_gain": 1, "pwr_idx": 3},
{"rf_power": 14, "pa_gain": 2, "pwr_idx": 4},
{"rf_power": 16, "pa_gain": 2, "pwr_idx": 5},
{"rf_power": 20, "pa_gain": 3, "pwr_idx": 6},
{"rf_power": 23, "pa_gain": 3, "pwr_idx": 7},
{"rf_power": 25, "pa_gain": 3, "pwr_idx": 9},
{"rf_power": 26, "pa_gain": 3, "pwr_idx": 11},
{"rf_power": 27, "pa_gain": 1, "pwr_idx": 14}
"radio_1": {
"enable": true,
"type": "SX1250",
"freq": 917900000,
"tx_enable": false
"chan_multiSF_All": {"spreading_factor_enable": [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
"chan_multiSF_0": {"enable": true, "radio": 0, "if": -400000},
"chan_multiSF_1": {"enable": true, "radio": 0, "if": -200000},
"chan_multiSF_2": {"enable": true, "radio": 0, "if": 0},
"chan_multiSF_3": {"enable": true, "radio": 0, "if": 200000},
"chan_multiSF_4": {"enable": true, "radio": 1, "if": -300000},
"chan_multiSF_5": {"enable": true, "radio": 1, "if": -100000},
"chan_multiSF_6": {"enable": true, "radio": 1, "if": 100000},
"chan_multiSF_7": {"enable": true, "radio": 1, "if": 300000},
"chan_Lora_std": {"enable": true, "radio": 0, "if": 300000, "bandwidth": 500000, "spread_factor": 8},
"chan_FSK": {"enable": false}
"gateway_conf": {
"gateway_ID": "0016C001F15D658F",
/* change with default server address/ports */
"server_address": "au1.cloud.thethings.network",
"serv_port_up": 1700,
"serv_port_down": 1700,
/* adjust the following parameters for your network */
"keepalive_interval": 10,
"stat_interval": 60,
"push_timeout_ms": 100,
/* forward only valid packets */
"forward_crc_valid": true,
"forward_crc_error": false,
"forward_crc_disabled": false,
/* GPS configuration */
"gps_tty_path": "/dev/ttyAMA0",
/* GPS reference coordinates */
"ref_latitude": 0.0,
"ref_longitude": 0.0,
"ref_altitude": 0,
"servers": [
"serv_enabled": true
"debug_conf": {
"ref_payload":[
{"id": "0xCAFE1234"},
{"id": "0xCAFE2345"}
"log_file": "loragw_hal.log"
Kind regards,
Pete Smith
