Test Procedure for defective SX1303 LoRaWAN Gateway Module/HAT for Raspberry Pi
Hi All,
I’ve been trying to get my HAT to place a Raspberry Pi 4 on The Things Network. I’ve tried various Raspbian releases (Bullseye → Trixie) with limited success. On later releases of Raspbian I am using some updated scripts to deal with the deprecated ‘echo > /system/class/gpio’ pattern that instead use the gpioset command.
At this point I’ve tried most things found on this forum and the wider internet support community. Just wondering if anyone has a working setup and could provide a set of commands with output to show how the working hardware should respond.
I.e. run this command → get this output.
I’ve run gpioinfo with/without the HAT - before and after running the reset script but the output looks the same.
Only the “sudo i2cdetect -y 1” command gives different chip output with the HAT installed on the PI:
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – 39 – – – – – –
40: – – – – – – – – – – – – – – – –
50: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – —
With the HAT I get the ‘39’ value.
Any help would be appreciated.
Thanks.
Hi @phillip168481 , welcome to the forums!
This is a bit out of my area, so hopefully someone else can jump in with some helpful information!
The output you are getting from i2cdetect tells us that, at least, the HAT is being detected by the Pi at the expected I2C address (0x39), so your physical connection is likely correct.
Hi Phillip,
Welcome to the forum!!
Just to confirm, was it this HAT you were using? SX1303 915M LoRaWAN Gateway Module+HAT for Raspberry Pi | Buy in Australia | WS-22613 | Core Electronics
What happens when you run:
# get sx1302 EUI -- Pi 4B
cd ~/Documents/sx1302_hal/util_chip_id/
./chip_id
from the guide?
Hi Liam,
Here is my output from chip_id:
lora@lorapihub:~/src/sx1302_hal/util_chip_id $ ./chip_id
CoreCell reset through GPIO23…
SX1261 reset through GPIO22…
CoreCell power enable through GPIO18…
CoreCell ADC reset through GPIO13…
gpioset: unable to request lines on chip ‘/dev/gpiochip0’: Device or resource busy
Opening SPI communication interface
Note: chip version is 0x00 (v0.0)
ERROR: Failed to set SX1250_0 in STANDBY_RC mode
ERROR: failed to setup radio 0
ERROR: failed to start the gateway
Note this is calling my updated reset script because I’m on Trixie.
Ok there definitely seems to be a GPIO conflict somewhere. I would be curious to see the output of:
gpioinfo /dev/gpiochip0
Hopefully it will shed some light on this.
Hi Jane,
I have captured the gpioinfo status before and after the reset script runs.
Here is the status after a cold boot:
lora@lorapihub:~ $ gpioinfo
gpiochip0 - 58 lines:
line   0:	"ID_SDA"        	input
line   1:	"ID_SCL"        	input
line   2:	"GPIO2"         	input
line   3:	"GPIO3"         	input
line   4:	"GPIO4"         	input
line   5:	"GPIO5"         	input
line   6:	"GPIO6"         	input
line   7:	"GPIO7"         	output active-low consumer="spi0 CS1"
line   8:	"GPIO8"         	output active-low consumer="spi0 CS0"
line   9:	"GPIO9"         	input
line  10:	"GPIO10"        	input
line  11:	"GPIO11"        	input
line  12:	"GPIO12"        	input
line  13:	"GPIO13"        	input
line  14:	"GPIO14"        	input
line  15:	"GPIO15"        	input
line  16:	"GPIO16"        	input
line  17:	"GPIO17"        	input
line  18:	"GPIO18"        	input
line  19:	"GPIO19"        	input
line  20:	"GPIO20"        	input
line  21:	"GPIO21"        	input
line  22:	"GPIO22"        	input
line  23:	"GPIO23"        	input
line  24:	"GPIO24"        	input
line  25:	"GPIO25"        	input
line  26:	"GPIO26"        	input
line  27:	"GPIO27"        	input
line  28:	"RGMII_MDIO"    	input
line  29:	"RGMIO_MDC"     	input
line  30:	"CTS0"          	input
line  31:	"RTS0"          	input
line  32:	"TXD0"          	input
line  33:	"RXD0"          	input
line  34:	"SD1_CLK"       	input
line  35:	"SD1_CMD"       	input
line  36:	"SD1_DATA0"     	input
line  37:	"SD1_DATA1"     	input
line  38:	"SD1_DATA2"     	input
line  39:	"SD1_DATA3"     	input
line  40:	"PWM0_MISO"     	input
line  41:	"PWM1_MOSI"     	input
line  42:	"STATUS_LED_G_CLK"	output consumer="ACT"
line  43:	"SPIFLASH_CE_N" 	input
line  44:	"SDA0"          	input
line  45:	"SCL0"          	input
line  46:	"RGMII_RXCLK"   	input
line  47:	"RGMII_RXCTL"   	input
line  48:	"RGMII_RXD0"    	input
line  49:	"RGMII_RXD1"    	input
line  50:	"RGMII_RXD2"    	input
line  51:	"RGMII_RXD3"    	input
line  52:	"RGMII_TXCLK"   	input
line  53:	"RGMII_TXCTL"   	input
line  54:	"RGMII_TXD0"    	input
line  55:	"RGMII_TXD1"    	input
line  56:	"RGMII_TXD2"    	input
line  57:	"RGMII_TXD3"    	input
Here is the status after running the reset script:
lora@lorapihub:~/src/sx1302_hal/tools $ gpioinfo
line  13:	"GPIO13"        	output consumer="gpioset"
line  18:	"GPIO18"        	output consumer="gpioset"
line  22:	"GPIO22"        	output consumer="gpioset"
line  23:	"GPIO23"        	output consumer="gpioset"
Thanks for your help.
Phillip
Hey Phillip,
We are recreating your setup on our end to help troubleshoot this, and ran into the same issue it sounds like you experienced, where the library tries to use the olde,r outdated GPIO method.
It sounds like you got past that hurdle already. Would you be able to share a link or some instructions for how you overcame this so that we can more accurately replicate your setup?
Thanks!
Thanks Samuel,
Here is the library I used:
Amongst the changes it updates the original scripts to make them more compatible with Trixie. This repo uses the new ‘gpioset’ commands. The old https://github.com/Lora-net/sx1302_hal script uses a deprecated ‘echo > /system/class/gpio’ pattern.
Please let me know if you need any more info - I’m pretty sure that’s all I did but did so many changes its possible I have hacked something else to get further.
Phillip
Hey @phillip168481 ,
Thanks for sharing that link. I was able to get this working on a test setup using a Pi 4, so that library hopefully isn’t the problem.
Would you be able to try again from a fresh SD install of the latest version of the Pi OS, make sure I2C and SPI are enabled through the raspi-config interface, and that github library?
If that still doesn’t work for you, then some photos of your physical setup would be helpful as its likely a hardware problem after that.
Hi Samuel, I did a fresh build and enabled the I2C and SPI interfaces. I tried reseating the HAT a few times - with and without the supplied riser and it made no difference to my previous results. I also tried without the stand-offs to see if I could get a better connection (as per the photo).
Thanks for that, @phillip168481,
Based on the difference results you and Sam are getting, I think this would be worthwhile escalating to Tech Support and exploring as an RMA.
Could you please email us at support@coreelectronics.com.au linking to this thread with a photo of the front and back of the Pi and HAT and we can move onto getting this resolved as quickly as possible.
Thanks Jane - I just through the email to support.
