Hi, does anyone know the Raspberry Pi Zero W case/Enclosure(official) with the camera faceplate can fit Pi Zero WH with the camera module? Thank you.
Hi Yuesheng,
Welcome to the forum!
Unfortunately, the only faceplate that works with the Zero WH is the one with cutouts for the GPIO from experience. If you need access to the GPIO you solder the headers onto the underside of the Pi (Heads up this will flip the way you have to attach a HAT or BONNET so it might not work!).
Core also has this camera case that gives a bit of room in the enclosure: https://core-electronics.com.au/the-pi-hut-pi-zero-camera-case.html
Liam.
Thank you so much.
