Continuing the discussion from OLED Display Module for Raspberry Pi Pico, 1.3inch, SPI/I2C (64×128) (CE07878):
2026 Update
Hi Team,
I have now made and sold about 20 of these. This year I was asked by a couple of NZ guys to make them a couple of these which I did but I had to change the design to use the Pimoroni Pico LiPo 2 (which worked out better) because the Maker Pi Pico Mini’s weren’t available at the time and I have also improved the display case.
I am also experimenting with adding a second sensor to report RH & Barometric pressure but is hasn’t really been much help for finding thermals.
The biggest change of late has been a new “Big Screen” version 6 using the “Large OLED I2C Display (SSD1309)” SKU: CE09964 which is good because it makes it much bigger and easier to see and it has a metal frame protecting the fragile glass display.
I had to change my code for the display from SPI to I2C and I also needed to add Pull Ups to the I2C pins because the display was corrupting, but adding a couple of lines of code to set the pullups on the appropriate pins sorted it out.
I’m donating this one to the Australian Team to take to the World Championships in Mongolia this year. I found that they fit nicely into a tinny cooler so I had some made up.
