As can be seen in the image, I followed the instructions on the product page and made the following connections:
- Vin to batteries(about 4.3V)\
- Pull shutdown to Vin
- Connect GND to battery gnd
- Connect a 10k resistance at Vout and GND
However, when I used a multi-meter to measure Vout, it showed 0V. We also tested Vin-GND which is about 4.3V and Vshutdown - Vin, which is about 0V. So both were correct.
Is it due to wrong connections? or is this voltage regulator simply a faulty component?
