This is a placeholder topic for “USB GPS Receiver” comments.
This GPS receiver brings much more accurate and faster positioning performance with stronger signal compared with traditional GPS receivers. It is compact, lightweight…
Read moreThis is a placeholder topic for “USB GPS Receiver” comments.
Read moreI have one of these. I connect it to my phone and display the data thru an app I built. Any serial terminal app on the phone will show the sentences immediately (no programming needed).
If you do want to use it on your phone you will need an OTG cable which Core has in their shop.
Hi John,
I love hearing these are getting use in some different use cases!
For those who want an OTG Cable here you are.
Is this compatible for ipad pro non cellular
Hey @Ashish301716,
Welcome to the forum!
iPadOS does not take location from generic USB/serial (CDC‑ACM/NMEA) GPS receivers into the system’s Location Services. That means most apps (Apple Maps, Gaia, ForeFlight, etc.) won’t see it unless the app explicitly supports that exact USB GPS. So this is not likely compatible.
