This is a placeholder topic for “USB/TTL Raspberry Pi GPS Tracker” comments.
USB/TTL Raspberry Pi GPS tracker is a small GPS location module. It is using L80-39 GPS chip, which includes 66 search channels and 22 simultaneous tracking channels. … read more
9 posts were split to a new topic: GPS Tracker Question
so i have followed the instructions on USB-Port-GPS Module SKU:EZ-0048 - 52Pi Wiki
I cant get a lock. When I do a sudo cgps -s
all I get is Time and time offset displaying everything else as N/a and no fix.
I performed a cat /dev/ttyUSB0 device or resource busy.
Its the only thing using usb.
Also under the /etc/default/gpsd for gpsd_options="-F /var/run/gpsd.sock <— is it sock or socket and is there a space between gpsd. and sock/socket?
PS. I have serial enabled under raspi-config anything else I need enabled maybe?
Ok so update. Managed to get a lock.
However, following instructions on this website: https://wiki.52pi.com/images/3/39/10.How_to_use_GPS_module_for_real-time_location_and_PPS_clock_synchronization_service.compressed.pdf
If I do a ntpq –pn, I only get pps showing and not the gps.
Is there something wrong in them instructions?
