I want to power my astronomy gear which takes 12v 5A barrel plug, however this cable talks about supplying 9v only. A 100W PD USB-C can supply plenty of juice, but is this cable suitable for 12V?
As Jeff mentioned, if you need 12V power you would need the 12V specific cable. You would need for the PD USB-C supply that you use to be capable of 12V and also of the current required (it should mention it on the power supply itself, similar to the photo below)
Thanks - didn’t realise there was also a 12v version of this cable.
P.S. Pity the USB-C PD standard doesn’t support 12v/5A which would be good for my astronomy power needs, and which this cable would support (5A). Seems 12v/3A is as high as the PD standard goes, not 5A - ironic since at higher voltages e.g. 20v 5A is indeed supported by the PD standard.
