Using USB-C Monitors with a Raspberry Pi 4
I want to use a Raspberry Pi to stream VLC Media Player via WiFi from a device and display it on a portable monitor.
The catch is that my portable monitor, the Asus mb16ace portable monitor only has USB-C input. I don’t know if I can use a Micro-HDMI to USB-C converter to plug the pi to the portable monitor.
It’s a Raspberry Pi 4
What do you think best option is? I can by a different model Raspberry Pi if that makes life easier?
Hi Steve,
I think you’ll need an active converter such as the one below, as USB-C uses DisplayPort under the hood, which can’t be passively converted to from HDMI (but interestingly the opposite works).
https://www.lindy.com.au/hdmi-to-usb-type-c-converter-with-usb-power
Unsure where to find one that’s in stock. as generally people want to go from a USB host (laptop) to HDMI peripheral (monitor)
Thank you.
Such a hassle that the only input is usb C. Wasn’t really thinking when I bought it.
I will
Give your suggestion a go. Cheers
