Vibrating Mini Motor Disc (ADA1201)
Hi Dee,
Welcome to the forum!!
Due to the motor only being able to output 0.5W I dont think there will be quite enough movement.
A quick TLDR of the topic linked below: if you want some heavy/customisable vibrations a DIY vibrating motor might be your best bet (or taking apart a gaming controller), grabbing a hobby motor and attaching an offset mass (a metal nut is cheap and easy to get a hold of).
I’d check out this topic: Vibration motor with strongest vibrations - #6 by Elmar155474
On how to get the biggest vibrations from a motor, there is also the surface transducer @James linked above: Medium Surface Transducer with Wires - 4 Ohm 3 Watt | Adafruit ADA1785 | Core Electronics Australia
Let us know how you go!
Liam
