The specifications on ADXL345 Triple Axis Accelerometer (GY-291) | 018-GY-291 | Core Electronics Australia refers to “Module supply voltage range: 4.0 V to 6 V”, however, Analog Devices in their specs for ADXL345 Supply voltage range: 2.0 V to 3.6 (https://www.analog.com/media/en/technical-documentation/data-sheets/ADXL345.pdf). looking at similar modules on the Internet there seems to be two sets of competing voltage - 4V to 6V or the 2V to 3.6V - for example Sparkfun equivalent module is 2V-3.6V.
What is the correct input voltage for this module ??? - the reason I ask is that the intended Microcontroller is 3.3V so ideally it would connect directly to the Vcc on the module.
Thank you.
Hi Yaron,
Welcome!
Given the price point of this one I don’t think there would be a lot of documentation around on the internet, it does however look like there’s an onboard regulator to bring the Vin pin to a higher range
Could you swap out the ADXL345 for an MPU6050 or another IMU? https://core-electronics.com.au/catalogsearch/result/?q=mpu6050
Thank you. I will check if not too late to swap out but I suspect it is.
Hi Yaron,
Even if it is if you have a soldering iron and want to have a stab at doing some modifications you could probe around to find the 3.3v output and short it to Vin.
Great idea. Thank you.
