G’day , good advice Bob, with water proof connectors, that might be ok on this, I’ll have to consider that if it doesnt build up to much heat,
Conformal coating has been fine so far at coating the appropriate parts, hasn’t hurt anything or effected performance in the slightest, it’s seen about 20hrs flight this week and hasn’t showed any negative signs yet,
That’s good that theres a low chance of it dieing if I go in the water because of its resistance,
So I probaly don’t have to push it too far is what I’m gathering, I am near the beach, so I guess my property might have more contaminants, but it should hopefully be fine still I doubt there’s that much, the grass isn’t inhibited at all unfortunately haha
Probably no need to spray anything in moving parts on a drone, Brushless motors are water proof anyway arnt they? Apart from the bearings
And a great idea blowing it off with air, that’d be my go to aswell if I got it soaked, I’ve got a couple of those emax ones, freestyle 2 and tinyhawk2s, Ive seen good stuff about them surviving after drowning aswell
So it’s sticky stuff is it Bob, I’ll keep that in mind if I use it, the way im planing to I’ll be injecting it in place, rather than spraying it, it’s not a beauty contest either just has to work if I land in water, they can be washed with isopropyl if it gets to bad, so it’s probably not an issue with this as far as I can see, we’ll see about that tho, it could be annoying more than it helps
Also I emailed the company of the product I mentioned “corrosion X” and they got back to me saying it’s fine to use in a USB and no need to remove it to use the usb, along with a link to the video I linked above, saying I think you’ll be interested in this, so I guess I’ll see what it’s like
In the mean time I’ve come up with another way I thinks not bad Mabey better, a tiny square of electrical tape over the parts then a tiny dot of e600 glue, as crazy as it sounds I’m pretty sure it’s sealed now, or at least fairly water resistant, Im happy with it like this, it’s relatively easy to replace when I have to aswell, I can’t see a need for going to extra lengths, this was too easy and clean,
The resistance of water, what I’ve done and being smart about drying and restarting it, well, I have good confidence I definately won’t have bad failure if I go in. Id like to make a drone that can fly in rain next
Cheers Cody
