Waveshare display Mini-HDMI to VGA cable pinout
Hi all,
I was needed Waveshare display mini-HDMI to VGA cable pinout ,
Since in India that cable non stock for more than 5 months and I can’t able to use that function
Does any one have it please help me to prepare an custom cable for my unit.
Thanks in advance
Unfortunately, this is not a passive pin-to-pin mini-HDMI to VGA cable. HDMI and VGA are electrically incompatible:
  • HDMI is digital TMDS signaling.
  • VGA is analog RGB with separate syncs.
So, what Waveshare ships is a mini-HDMI to VGA converter (tiny active electronics inside the molded connector). That’s why you can’t just make a cable by wiring mini-HDMI pins to VGA pins — the signals don’t match. The converter chip (often a CH7101 or similar HDMI to VGA bridge) does all the work.
Hiya @Eswaran303023 and welcome to the forum,
Could I please confirm do you need the mini-HDMI to VGA Male cable or were you after the Pin Out Diagrams for the cable?
If for the former, Core Electronics does sell a Mini-HDMI to VGA Converter. It looks like it would require a lead time to get shipped however.
I was not sure on this
When you look on the display spec it was mentioned as Supports vga input on mini HDMI connector,
I think VGA port does carry any supply for conversion like HDMI,
Hi thanks for the welcome,
I need the cable or its pinout diagram.
But Cable not possible in my region, since we have issue with USD payment, there is no buyable option in rupees.
And I have checked all over for that cable pinout , didn’t found any clue , so that come to put here, if anyone has that cable / pinout details
i Eswaran
If you google “Waveshare display mini-HDMI to VGA cable” you will get quite a number of hits rom vendors with pricing in Euros. This might suit you better than $US.
Although I find it strange that you can’t purchase in $US . If you have a PayPal or similar account the conversion is done for you.
Hi Robert,
Actually there is limitations on my office on the purchase.
So only this much complications,
I can’t go for other payments except rupees.
Hi Eswaran
Well you will have to find an outlet in India.
Or as you requested the wiring information and make one if you can get the connectors.
Hi @Eswaran303023,
The best I can offer after extensive searching is just general information.
Mini-HDMI Pin Out:
VGA Pin Out:
And the General Idea of the Conversion:
Hope this is at least a little helpful.
Oh and this design for a converter.
HDMI-to-VGA (HDMI2VGA) Converter Block Diagram
Thanks for the input
I have teardown the display mini HDMI to RTD2662 IC ,
Connections are made as below,
R0+ → VGA Pin 1 (Red)
G0+ → VGA Pin 2 (Green)
B0+ → VGA Pin 3 (Blue)
AHS0 → VGA Pin 13 (HSync)
AVS0 → VGA Pin 14 (VSync)
All VGA grounds (Pins 5, 6, 7, 8, 10) → tie to board’s AGND, and also to R0−/G0−/B0− pins of RTD2662
I will get connectors and made custom cable and tell feedback.
Thanks for the support
Wonderful, glad I was able to help. Let us know how it goes. :slight_smile:
Several years ago I tried a HDMI to VGA converter to use my old VGA screen with a Raspberry Pi. It did work … sort of … but the quality was not good, and it did not take long to convince me to buy a HDMI monitor. I tried a second converter, but the result was the same.
Hopefully the products sold by Core Electronics, and the circuit given above, use newer components which give a better result … but I suggest you buy a HDMI screen instead. At least you should have no trouble buying one in India.
As per above pin out I have made mini HDMI to VGA cable
That’s works perfectly.
So waveshare uses mini HDMI as an connector for size concern in their display
