I am looking at this wifi module, with the intention to remotely control a temperature setting.
I have no issue with connecting / serial comms to the module at this stage.
But what would be the simplest option / software available to connect to the module from either an app or a pc ?
The easiest option I can suggest would be to use Blynk.
It’s a brilliant app for control of IoT devices with easy GUI all on a smartphone.
This tutorial will step you through controlling an LED using your smartphone, Blynk and an ESP8266, it’s a simple start but the possibilities are limitless from there!
