27W 3 - 12VDC Switchmode Plugpack with USB Outlet (CE04425)
This is a placeholder topic for “27W 3 - 12VDC Switchmode Plugpack with USB Outlet” comments.
These switchmode plugpack adaptors are slim in size, lightweight, and feature manually selectable variable voltage outputs. All are MEPS compliant and come supplied with 7 plugs and a USB output socket.
This product has 7 output plugs. Do you have the sizes available, and in particular, are any of them the 5.5mm OD / 2.1mm or 2.5mm ID (+ on centre) often used on 12V outputs?
Hey there, @Roger110082, and welcome to the forum. Glad to have you here.
I managed to find the exact specifications for each plug buried on a supplier website. The plugs are as follows:
I believe the first value would be I.D, I’m not sure why it’s listed as DC…
