This is a placeholder topic for “7 Segment Display (2-Wire, 0.5”)" comments.
Perfect for when you need to display the time or some simple sensor read-outs, all with two pins!
Read moreThis is a placeholder topic for “7 Segment Display (2-Wire, 0.5”)" comments.
Read moreCan someone recommend a mounting kit for this? (Preferably with spacers so I can mount it flush with some acrylic and have the pins safely underneath)
These kits are very useful for mounting parts, although a little expensive.
Core also has M2 & M3 kits.
Hi @James46717
From the product description
M2 37mm x 20mm mounting holes to make mounting and viewing easy.
Is M2.5 different form M2?
I can see alot of M3 but not many M2 Kits.
M2 kits I have found very useful.
PS the M refers to the size in mm.
Hi Pixmusix
Yes, 0.5mm larger in diameter.
As Jim says
