Adafruit DS3231 Precision RTC Breakout (ADA3013)
This is a placeholder topic for “Adafruit DS3231 Precision RTC Breakout” comments.
The datasheet for the DS3231 explains that this part is an “Extremely Accurate I²C-Integrated RTC/TCXO/Crystal”. And, hey, it does exactly what it says on the tin!..
Howdy, I have a RaspberryPi 4 B and was wondering if the Adafruit DS3231 Precision RTC will fit in the Argon ONE V2 case with the Expansion Board board attached?
I think it’s not possible to tell without test-fitting.
Hi Daniel,
Welcome to the forum! I think its unlikely that you will also fit this in the case. The Pi’s GPIO headers poke out the top so you will at least have wires running out of the case anyway. This clock should be small enough to tuck behind your Pi anyhow.
Hi Jack, sorry for delay but thank you very much for this info.
