I recently purchased the Adafruit 1.54 TRI-COLOR EINK / EPAPER 200X200 DISPLAY WITH SRAM - SSD1681 DRIVER display for a project I’m trying to put together as I needed a low power consumption display that’s going to update data once per hour, so this display seemed perfect.
Sorry we didn’t get to this one sooner. No obvious issues jump out at me as to why this shouldn’t have worked for you. I’ll take one of the displays from the warehouse in the morning and replicate your setup here in the support office, then we can go from there to see why it’s not working as expected.
I was just trying to double-check your wiring from the first photo. The 3.3V to Vin, Gnd, SCK, MISO, and MOSI look right to me, but it appears that the ECS pin of the display is connected to digital 10 in your photo. Could you send us another couple of photos of the wiring at the UNO and the wiring into the breadboard?
I’ve rechecked the wiring and retried to upload a code. One less issue, the Uno no longer locks up, so something was amiss, but the display still doesn’t refresh.
#define EPD_DC 10 // can be any pin, but required!
#define EPD_CS 9 // can be any pin, but required!
#define EPD_BUSY 7 // can set to -1 to not use a pin (will wait a fixed delay)
#define SRAM_CS 6 // can set to -1 to not use a pin (uses a lot of RAM!)
#define EPD_RESET 8 // can set to -1 and share with chip Reset (can't deep sleep)
Sorry, we didn’t have a solution for you this time and couldn’t pinpoint the problem quickly. We’ll treat this unit as defective and organise a replacement via email to get you back on track.
We’ve gotten in touch via email, as returns are handled there. Have a read of the email from my colleague, it goes over what we do and don’t need from you going forward. Get back to us there if you have any questions
