This is a placeholder topic for “Adafruit RFM69HCW Transceiver Radio Breakout - 433 MHz” comments.
"You see, wire telegraph is a kind of a very, very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? And radio … read more
Are there micro python libraries available for these radios
Hi Tim,
Depending on the microcontroller you run with you could even use Circuitpython.
It looks like someone as a repo up with a port here: GitHub - arkorobotics/rfm69-micropython: Micropython library for the RFM69
