Adafruit Ultimate GPS HAT for Raspberry Pi - Mini Kit (ADA2324)
This is a placeholder topic for “Adafruit Ultimate GPS HAT for Raspberry Pi - Mini Kit” comments.
It’s 10 PM, do you know where your Raspberry Pi is? If you had this GPS HAT, you would! This new HAT from Adafruit adds Adafruit’s celebrated Ultimate GPS on it, so you…
Looking at an Ultimate GPS hat or the breakout version. I need PPS and to connect to pin 12 on the GPIO on the Rpi , it says in the info the hat version PPS is connected to Pin 4 ? Can this be changed ? Want to create an accurate time server
thanks for any assistance
Cliff
Hey there, @Clifford881,
From Adafruit Learn’s instructions, Adafruit Ultimate GPS HAT for Raspberry Pi`, looks like probably not. Here it shows the instructions to modify the kernel to handle PPS on Pin 4. They specifically state that the HAT uses Pin 4, which to my mind that would mean pin configuration is non optimal.
