I have an Adafruit Ultimate GPS HAT that was working fine on an RPi4 running the latest version of Raspberry Pi OS 32-bit. I wanted to move to 64-bit so I could use some software that was for arm64 instead of armhf so I loaded that onto a new SD card after backing up the old config to carry it over.
The GPS HAT has not worked since and the only change I made was to swap the SD-cards with one running 32-bit Pi OS and the other 64-bit. The HAT still gets a fix very quickly and holds it according to the HAT LED.
Since this time, I’ve tried all kinds of isolation techniques and as it stands now, I have the HAT on a different Pi, with a fresh install of Ras Pi OS 64-bit and it’s still not seeing anything from the serial output.
This is the sum of the actions I have taken on the new device:
Logged in
Enabled serial port but disabled serial loging
Configured /boot/config.txt for dtoverlay=disable-bt
systemctl disable hciuart
systemctl disable bluetooth
This python script just hangs:
#!/usr/bin/python3
import serial
from time import sleep
ser = serial.Serial ("/dev/serial0", 9600) #Open port with baud rate
while True:
received_data = ser.read() #read serial port
sleep(0.03)
data_left = ser.inWaiting() #check for remaining byte
received_data += ser.read(data_left)
print (received_data) #print received data
# ser.write(received_data) #transmit data serially
I can see you’re aware of the whole mini-uart thing, have you gone through this whole section of the Pi docs to confirm you’ve ticked all the right boxes?
So I have had a read of this documentation and it’s probably confused me even more.
If I am not mistaken, the UART I’m trying to enable is the PL011 UART as UART0 and my primary UART which should then in turn be on /dev/serial0 and /dev/ttyAMA0. I want to be disabling the mini-UART because this won’t function correctly.
I don’t have access to either unfortunately but I can probably create a loopback cable to test. That said, I’d rather hope I haven’t fried serial on 2 separate Pis somehow but I’ll give this a shot and report back.
So i tried to do a loopback test. Mashing some keys didn’t yield anything but I eventually got dropped to a login screen which I thought was odd given I have disabled the console on serial.
I don’t think the cable I was using was great quality though, so I’ll go get a new one and try again, but it sounds to me like the test has failed?
dmesg | grep serial
[ 1.603630] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.606646] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.609463] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
[ 45.632750] uart-pl011 fe201000.serial: no DMA platform data
[ 3684.249411] uart-pl011 fe201000.serial: ttyAMA0 (0): invalid RTS setting, using RTS_ON_SEND instead
I’m not sure what I am supposed to be seeing with screen /dev/serial0 9600. When I do this and mash the keyboard, it just kinda sits there and does nothing. Eventually it might clear the screen but thats it.
