Dear all,
I need help on an air filling project which involves:
SV 1 - 12V 2-Position 5-Way Solenoid Valve with Outlet wire
SV 2 - 12V 2 Way Electric Solenoid Air Valve with Outlet wire
SV 3 - 12V 2 Way Electric Solenoid Air Valve with Outlet wire
AP - Portable Air Pump/Compressor for Car Bike 150PSI with 6000mAh Battery 150PSI
PAC - Pneumatic Air Cylinder
MS - On/Off Micro Switch with Lever AC 5A
Power source: 6000mAh Battery
Controller: Raspberry or Orange Pi
Step 1: MS activated in On position
Step 2: AP activated (turned On)
Step 3: SV 1 activated which controls PAC to UP position
Step 4: SV 2 activated which controls 1st air flow to a certain psi
Step 5: SV 3 activated which controls 2nd air flow to a certain time frame (for example 2 seconds)
Step 6: SV 1 activated which controls PAC to DOWN position
Step 7: AP deactivated (turned Off)
Thanks!
