A button is a button, and a switch is a switch, but these translucent arcade buttons are in a class of their own. Particularly because they have LEDs built right…
Does a datasheet exist for this product?
I have dreams of the led only lighting up when the button is compressed.
Just wanting to see what each pin is doing and if the data pin talks to 5v and ground internally.
Thanks in advance.
We don’t have a datasheet for that one, but the description tells you pretty much all you need to know - it has 2 LEDs in parallel, each with their own series resistor, and the button is separate to that. If you wanted the functionality you mentioned you could wire it up like so:
Thanks @James for that diagram.
First time reading a diagram like that, very exciting.
If it’s OK by you my plan is to sit down with the button tonight and just … give it a go best I can figure it. I assume I can’t really break anything by accident with only 3.3v.
If I can’t get it to work because I did it wrong, is it OK if I snap a picture of my breadboard wiring and post it back here for corrections?
Surprised you’ve come this far without seeing a schematic! They are the standard way of showing exactly what connects to what.
I’d just carefully read the product description to work out exactly which pins are which (maybe draw a diagram for future reference) and try and assemble the circuit as shown. If it doesn’t work, come back and let us know, we’d be happy to help troubleshoot.
