Hi Samuel, Thank you for quick response.
Target board is Waveshare ESP32 S3 Touch 3.5 ( happy to change hw if preferred)
I was using Arduino IDE, tried all the installing demos from Waveshare and other feeds, no luck, I just cannot get the display to work or the touch screen!
I am communicating with the target via the USB/Arduino IDE as I can upload a blink demo which blinks the display backlight, so I know board is good and it was working with the preinstalled demo from Waveshare before my first upload to the board.
I am new to Arduin but do have HW and some 6809 assembler experience.
To make things more complicated Waveshare brought out 2 versions of the board the ESP32 S£ Touch 3.5 and the ESP32 S3 Touch 3.5B. Who knows why 2 versions but I tried both libraries as I understand after much research the Display and Touch drivers are different for the two versions!!!
So after hundreds of trues and different libraries etc I am now totally confused…not sure what libraries to use anymore.
I’m putting down to no experience and not enough knowledge about teh ESP32 and the Arduino IDE!
My project is quite simple, just 2 lines of 6 digit numeric values one the incremental upcounter and the other the keyed in target count ( thinking display divided into two halves top and bottom, top incremental and lower the target count , maybe in 2 colours too). When Accumulator equal target count then GPIO to set ( count finished), display then reads Finished Batch, then waiting for GPIO input “Start” and so a new cycle starts.
Do need some variables for the count target value and need 4 parameters for 4 GPIO outputs referring to percentage of count completed at 50% set GPIO 70% set another GPIO 85% set another GPIO and the 98% set GPIO.
Count will be GPIO input ( high speed input) and simulation increment with button on touch screen or auto internal SW count for testing counters and output stages.
I will be in Sydney from 6th Dec and can pop by to discuss details ie HW and SW and a bit of 1/2 day crash training for me ( Arduino IDE) Happy to go with your HW if it is easier. I am keen to design the screen layout ( make it a bit fancy and modern looking) using something like Squareline.
Later once counter close to working well I would like to use the Bluetooth Wifi features of the ESP board so I can set parameters and read values from a mobile phone ( Android and IOS).
Have to say I have my knickers in a knot with Arduino IDE, maybe I jumped into the deep end too quickly because now with all the utube/arduino/github tutorials etc I am slightly overwhelmed hence my reaching out. I need a side by side quick lesson to just kick start me. I do like the Waveshare ESP32 S3 touch unit as it has all the features I need and its low cost and easy to buy.
Any further questions or direction let me know. I can send a flow chart if it helps…
Look forward to your suggestions…
Phil
