This is a placeholder topic for “Arduino Nano V3.2” comments.
The Arduino Nano is a small version of the Arduino UNO with a breadboard-friendly form factor. The board was originally designed by Gravitech.
What is a suitable socket for the Arduino Nano V3.2
It depends on why you are using a socket. If it’s for prototyping then you would use female 0.1" headers soldered into a prototyping board:
If it’s for experimenting with the device then you would use an expansion shield:
ZIF sockets are also available and can be used with a ptotoyping board to make a custom expansion shield (but check the width):
If you solder the Nano to a prototyping board then you can use whatever sockets that board supports:
Thanks Jeff
David
