Hello, I’m new to the forums, I would like to have a 12Vdc input from the reverse wire on my car to trigger a servo to turn (90°) and to turn back when it loses the signal (0°) it’s for the monitor of a revering camera in my Navara, I have an Arduino Uno3 and a servo shield, can I please have some as to the code, (12v signal trigger 90° servo movement) and the wiring to the arduino, I’m fine connecting the rest of the camera setup, thank you
Hey Andrew,
I believe that the following tutorial should help you with getting started in your project if you haven’t seen it already. Some settings will probably be a little different depending on the servo shield in particular that you’re using. But this should be a good place to start…
All the best with your project!
Bryce
Core Electronics | Support
