Hi, can anyone tell me what will plug into the GPIO socket on the Fan Hat? The holes seem too small for the 40 pin connector.
Thanks, Ian.
Thanks, Ian.
Hi Ian,
Was this the one you were after?
That HAT plugs straight onto a Pi’s 40-pin header just fine! (It may be overall bigger than you think!
Hi James, Yes I have the Hat you mentioned, I cant seem to be able to plug anything into the header socket. either a 40 pin strip that you normally solder to the Pi or a ribbon cable male plug.
Hi Ian,
If you space out your HAT correctly, you could definitely plug a male header into the top and bottom of your fan hat, I think. Forgive the crude drawing, but here’s what I mean:
Even if you don’t have standoffs, just pushing the Pi header in so that it only goes in about half way, or only in the “bottom header” should work.
EDIT: If you want to connect to a female IDC cable (or anything else female) something like this should do the trick:
