Six Kinds Light box final.stl (30.0 KB)
Hi there,
I hope you’re doing well.
Thank you for taking the time to speak with me.
Please find attached the models and the code I have been working on for your reference.
I have noticed an issue with the colour output when adjusting the brightness. When selecting purple, the colour appears closer to pink or red as the brightness increases. I have observed similar behaviour with orange and yellow. When the brightness is set to 100%, the colours seem to shift significantly towards red rather than displaying their intended colours.
I have also tried manually adjusting the RGB values, but this does not appear to resolve the issue. Additionally, when selecting white, the light appears more yellow than expected.
If achieving accurate colours is not feasible with the current setup, I would be happy to use a bright white light as an alternative, provided it produces a consistent and sufficiently bright output.
Could you please review the attached models and code to help identify the cause of these issues and recommend any necessary adjustments?
Thank you for your time and assistance. I look forward to hearing from you.
Jayson
