This is a placeholder topic for “Audio Amplifier Kit - STA540” comments.
This is a stereo amplifier kit designed to make use of the STA540 power amplifier IC. Once this kit is completed you have a fully functional, two-channel audio amplifier, complete with a standby switch, volume control and indicator LEDs. The kit also includes a 6400BG heatsink for the STA540 to dissipate any damaging heat.
Hi
I was hoping someone may be able answer a couple of questions for me regarding the STA540 audio amplifier kit (SKU: KIT-09612). I am aiming to build an amplifier/monitor for my Roland electronic drum kit. The usage would only be for home/personal use NOT for live gigs. I am also not after perfect audio, just something that will tolerate the attack of a drum hit and the frequency range from a bass drum to a cymbal. I would house it in a cabinet (I will construct) and a single speaker.
My questions are:
- Are the 2x 10k Giant Trimpots in the kit that are designated Left and Right on the PCB to control the volume of the left and right output channels? I was wanting to have 2 inputs – electronic drums (mono) in one, and external music source (mp3 player mono) in the other so I can play along with music. Given the output is to be mono, I was thinking I could use the left/right channels for these 2 inputs and use the volume controls to level the drums against the music.
- Is the power source DC? If so can a generic DC adapter be used?
- Would a cooling fan be required or are the cooling fins enough?
- Can the stereo outputs be wired to a single speaker as simply as the left and right positive wired to the speaker hot terminal and the left/right negative to the speaker negative terminal or is some sort of mixing component required between to achieve this?
I hope this all makes some sort of sense!
Stuart
Hi Stuart
I wouldn’t do tat at the speaker level.
You might have to do a bit more research but I think you may be able to link JP13 pins 1 and 2 to achieve a mono output (albeit on 2 speakers).
Someone else may be more up on this amplifier but this is the level I would be looking at combining the 2 channels.
- Yes - the volume controls operate separately on each channel.
- Yes - according to the specs power is 8v to 22v DC. The generic adapter will need to be able to supply sufficient power for the volume you intend to operate at.
- Depends on your application. Consistent loud volumes in a small or badly ventilated box with high ambient will require a fan. If those conditions don’t apply you would get by without a fan.
Stuart
Sorry I missed this bit.
It may be possible to operate this amplifier with a single speaker in “Bridge” mode. Some do support this, some don’t. Do NOT attempt to connect the two outputs in parallel. You will still have to combine the 2 channels somewhere as I suggested above.
Thanks Bob and Jeff for your replies. It has helped me a lot.
Stuart
