Greetings,
I would like to make a prop chainsaw for halloween this year with loud realistic sound.
I intend to gut and old real chainsaw and replace inside with -
Adafruit Audio FX Sound Board + 2x2W Amp - WAV/OGG Trigger - 2MB
I should be able to run wires to 2x seperate buttons to trigger sounds. 1x button for idle sound, 1x button for high rev chainsaw sound.
This board only has a speaker amp output of 2x 2w, Id like to have the output instead going to a large say 50w car speaker.
Is there something i can use after the onboard amp to boost the watt so i can use a large loud speaker while still remaining inside the chainsaw shell?
Also any links including buttons and PSU also very appreciated.
I will document the build as i go
